Disable options to user
aar
Post by aar »
can the user simply press Ctrl-Alt-Delete to end the program, and by pass it?
How do we switch from restrictions on the browser to lifting the restrictions, and back and forth?
thanks
[/i]
What operating system are you using?
To really secure Windows I would not recommend using Windows 95/98/ME.
If you are using Windows NT/2K/XP, then you can use Windows policies to disable Task manager from the Ctrl-Alt-Del dialog.
We run Windows 2000 and remap the keybaord using the keyboard remap utility found with the 2000 Resource Kit. It works pretty well, Ctrl-Alt-Del has been replaced with f10-f12-Del. So far no users have worked it out and my guess is why would they?
Sometimes the most brilliant solutions are the simplest ones. I will have to remeber this one.
