I currently am running PWB 3.05 CEF, and we have a page that comes up that displays multiple shortcuts to applications that can be launched from here.
However before the shortcut is launched the user gets a Windows Security window popup. Saying "You should only run the files that come from websites that you trust. X:\PWB"
How can I allow these links to be trusted so the user doesn't get this prompt every time before they launch the application?
PWB prompting with Windows Security Prompt
Re: PWB prompting with Windows Security Prompt
Please post a screen shot of what you are seeing.
I have attached the PNG file with the screen shot.
- SecurityWarningPWB.PNG (135.61 KiB) Viewed 37732 times
It looks like you have a PWB Internet Explorer tab open.
You need to add the URL to a zone and then lower the security for the zone to "Low". 1. From the Control Panel open Internet Options.
2. On the Security tab, click Trusted Sites icon to select it.
3. Click Sites button.
4. In the Add this website to the zone: text box type "file://X:/PWB/Applications".
5. Uncheck "Require server verification (https:) for all sites in this zone.
6. Click Add.
7. Click Close, OK.
- or -
2. On the Security tab, click Local Intranet icon to select it.
3. Click Sites.
4. Click Advanced.
5. In the Add this website to the zone: text box type "file://X:/PWB/Applications".
6. Click Add.
7. Click Close, OK.
Reference:
https://sway.com/1fXhruePaDdzYp8r
6. Click Add.
7. Click Close, OK.
- or -
3. Click Sites.
4. Click Advanced.
6. Click Add.
7. Click Close, OK.
Reference:
PWB Chrome windows opened to local folder.
PWB Internet Explorer window opened to local folder.
How do I add the location?
X:\PWB\APPLICATIONS
I have tried but it will not allow me under the trusted sites.
Please note, the X Drive on our server is actually hidden by default \\SERVERNAME\APPS$\PWB\APPLICATIONS
X:\PWB\APPLICATIONS
I was able to add the location to our Trusted Sites, and it does work when set to LOW security.
However due to security our network engineer does not want to change all the settings to LOW. Do you know what specific security setting will need to be toggled in order to allow this?
It would be a bit more work, but you could use the PWB dynamic external java commands to run local applications from a web page with JavaScript commands instead of open a folder on the computer.
More information:
https://www.teamsoftwaresolutions.com/b ... ernal.html
Set in INI:
[Java]
EnableExternalJava=True
JavaExecute=PWBExecute
More information:
Set in INI:
[Java]
function OnClickExecute()
if(isChrome)
pwb.PWBExecute('NotePad.exe');
else
window.external.PWBExecute('NotePad.exe');
<form><input type='button' name='execute' value='Execute command' onClick='OnClickExecute()'></form>Re: PWB prompting with Windows Security Prompt
I don't think that would work, as we have anywhere from 40 to 50 applications. We Use Access Based Enumeration to publish them so they are not visible to all users with the PWB.
Do we know what Advanced Security Settings need to be toggled to get it to work, instead of just flipping it all over to LOW?
- After some further testing it looks like I figured it out. Made the following change.
- change the Security Settings for the Local Intranet, Custom Level, Launching programs and files in an IFRAME (Change from Prompt to Enable).
