PWB version 3.20.00 Released
Locked
Version 3.20.00 08-19-2024
Fixed/Changed:
Changed to Microsoft Edge Browser WebView
Changed to include Print Preview in Only Access HTTP and Only Access Internet
Added:
[Browser]UseRAMCache=False Uses RAM for cahce instead of hard drive
[Browser]DisablePWBUserAgent=False Disables adding PWB to the User Agen String
[Security]DisableFileOpen=False Disables JavaScript open file dialog
[Security]DisableFileSave=False Disables JavaScript save file dialog
[Security]CheckProtocolAccess=False Enable Protocol filter
[Security]CheckJavaScriptAccess=False Enable JavaScript URL filter
[Security]DisableFileOpen=False Disable File Open Dialog
[Security]DisableFileSave=False Disable File Save Dialog
[Security]DisabledMessage= Message when dialogs are disabled
[Security]DisabledTitle= Title of message when dialogs are disabled
[Files]DisableFileDialogFile= Used with [Security]DisableFileDialog, when file is listed the dialog will show when File Dialog is disabled.
[Printer]CheckPrinterAccess Enable Print URL filter
[Printer]CheckPrinterFile Filter file for Print filter. +/-URL to allow printing. Similar to the URL filter
[Printer]CheckPrinterMessage HTML formatted message shown when printing is blocked.
[ContextMenu]Share= Enables Edge Context menu for Share
[ContextMenu]ScreenShot=Web Capture Enables Edge Context menu for Web Capture
[ContextMenu]CopyLink=Copy Link Enables Edge Context menu for Copy Link
[ContextMenu]CopyImage=Copy Image Enables Edge Context menu for Copy Image
[ContextMenu]CopyLocation=Copy Location Enables Edge Context menu for Copy Location
[ContextMenu]MagnifyImage=Magnify Image Enables Edge Context menu for Magnify Image
[ContextMenu]Emoji= Enables Edge Context menu for Emoji
[ContextMenu]PasteMatchStyle=Paste and Match Style Enables Edge Context menu for Paste and Match Style
[ContextMenu]SelectAll=Select All Enables Edge Context menu for Select All
[ContextMenu]Loop=Loop Enables Edge Context menu for Loop
[ContextMenu]ShowControls=Show Controls Enables Edge Context menu for Show Controls
[ContextMenu]SaveMediaAs= Enables Edge Context menu for Save Media As
[ContextMenu]CopyVideoFrame=Copy Video Frame Enables Edge Context menu for Copy Video Frame
[ContextMenu]PictureInPciture=Picture In Pciture Enables Edge Context menu for Picture In Pciture
Removed:
[Browser]MultithreadedMessageLoop
[Browser]UserAgentAdd
[Browser]UserAgentForce
[Browser]UserAgentSearch
[ContextMenu]Separator5
[ContextMenu]Properties
[ContextMenu]ViewSource
[ContextMenu]SavePicture
[ContextMenu]SetWallPaper
[ContextMenu]Spelling
[Highlight] Section
Locked
