Max_Path and cache
sjewkes
Max_Path and cache
Post by sjewkes »
We are encountering a problem where a users profile ends up with a cached file that exceeds the Max_Path of 255 chars. When this occurs the profile will become corrupt if it is deleted because this file cannot be removed.
Is this a PWB issue or an Internet Explorer issue? Is there a setting somehwere that will not allow a path to exceed 255 chars?
As always, thank you for your help.
Scot
Because PWB uses the IE HTML rendering engine, including all functionality dealing with the cache files, it would appear this would be a IE problem, not a PWB problem.
Have you tried applying all the patches for IE or upgrading to the newest version?
